Howling Wolves Collector Plate
issues-ssw25-Howling-Woves-LeadSeparate layers give depth to this wildlife scene
This design comes from the recently re-released book Wildlife Collector Plates. The beauty of these patterns is that you can mix and match the inner wildlife scene with your choice of rim designs to produce a variety of custom projects.
For added interest, attach a piece of mirrored acrylic to the back. Hang the plate on a wall or display your artwork in a free-standing plate stand.
After cutting and finishing the piece, it is rather simple to assemble. Add a few dabs of glue, silicon, or epoxy to each tab of the interior design. Align the rim over the tabs and press into position. Use the same procedure to glue the backing board onto the interior design.
  • 1/4″ x 61/2″ x 71/2″ hardwood of choice (interior design)
  • 1/8″ x 61/2″ x 71/2″ wood of choice (backing board)
  • 1/4″ x 9″ x 9″ hardwood of choice (outer rim)
  • Finish of choice
  • Wood glue, silicon or epoxy
  • #1 and #3 reverse-tooth blades or blades of choice
Wolves Outer Ring Pattern
Wolves Center Piece Pattern
