Reindeer Ornaments
Changing the size of the pattern gives you endless variations with these designs
The obvious uses for these patterns are ornaments or gift tag holders, but there are a variety of other possibilities.
-Enlarge the pattern, cut it out of plywood, and add holiday lights as a window decoration.
-Make the pattern very large, cut it out of exterior plywood, and place it in your yard.
-Add supports to the back and put a candle behind it to cast interesting shadows.
Step 1: Copy the pattern. Attach it to the wood, using your method of choice.
Step 2: Drill blade-entry holes. For the interior detail cuts, use a drill bit just large enough to feed the #3 blade, or your blade of choice, through.
Step 3: Cut the inside fretwork. Use the #3 blade or your blade of choice. Start in the center, and work our way out. Do the more delicate areas first.
Step 4: Cut the outline of the ornaments. Use a #5 blade or your blade of choice.
Step 5: Sand off any rough edges or burrs left by the cutting.
Step 6:Apply your finish of choice. After the finish dries, spray the entire project with clear lacquer.
Click the article attachment to download the patterns for this project.
Reindeer Ornament pattern
Reindeer Ornament #2
Reindeer Ornament #3
