Fauna and Fowl Trivet
Uncategorized
Folk art-style fretwork protects your table and decorates your kitchen
By John A. Nelson
Cut by Leldon Maxcy
This beautiful trivet is almost too pretty to cover with a hot pan or dish. The project is great for beginners and advanced scrollers alike, and anyone looking to add a special touch to their table setting.
Getting Started
Attach the pattern to the blank, drill blade-entry holes and the birds’ eyes, and cut the fretwork.
Cutting & Finishing
To cut the sharp corners in this trivet design, I suggest using flat blades. Choose a medium-tone or darker hardwood, such as cherry or mahogany; the darker wood hides any scorch marks from hot pots. Most film finishes, such as varnish or lacquer, will break down over time with the application of heat. I suggest Danish oil or another oil finish, which tend to soak into the wood and protect it without flaking off.
    Download the Pattern Here
Materials
• Hardwood, such as cherry or mahogany, 3/4″ (1.9cm) thick: 8″ square (20.3cm)
• Finish, such as Danish oil
• Scroll saw with blades: #3 reverse-tooth
• Drill with bits: 1/16″ (2mm)-dia.
John A. Nelson is the author of Fox Chapel’s popular Scroll Saw Workbook, available at foxchapelpublishing.com.
While you’re at it, purchase our winter issue!
Purchase our Winter Issue Here!
Subscribe
Subscribe to Short Cuts
